squeaking when turning left
Old Dec 27, 2007 | 09:58 AM
00IntegraLS's Avatar
Default squeaking when turning left
here in Wisconsin, it started getting bitterly cold about a month ago. At that time I had all my rotors replaced as well as my rear brake pads. Also, at that time, my car started squeaking. It happens more frequently on left turns, and when it's realllllly cold out it squeaks more often. It doesnt squeak every left turn either.
Also what I found quite bizarre, is that i was parked along the side of the road with my hazards on and i noticed it was squeaking to the beat of my hazards, not sure if its the same squeak but i found that odd. .... anyone know what could be the problem?
Also, a bit before the squeaking started i had a triple gauge pod installed with a volt meter, oil/fuel ratio, and oil pressure. not sure if this is relevant however
thanks
Old Dec 27, 2007 | 10:09 AM
Live_4it's Avatar
Default RE: squeaking when turning left
It could be the power steering belt since it's doing it while you turn. Have you pinpointed the exact location of the squeak?
Old Dec 27, 2007 | 05:46 PM
Squeaking to the beat of the hazard lights may indicate that the alternator belt is loose or glazed.
For squeaking when turning, check whether the power steering (PS) fluid level is low, as well as whether the PS belt is loose or glazed (as mentioned by Live_4it).
Old Dec 28, 2007 | 05:20 PM
alright last night when i was driving home i noticed it was squeaking when I was going straight as well. but i would definately still say that turning left has something to do with it because ive never noticed it while turning right, only when going straight or turning left.
im assuming the power steering belt is the belt right next to the power steering fluid container and i checked that and everything looks fine, i cant tell how full my fluid is but i took the cap off and i can definately see fluid, but i just cant tell if its in between low and high
Old Dec 28, 2007 | 06:59 PM
ORIGINAL: 00IntegraLS
The picture shows the relative locations of the PS, A/C, and alternator belts.
mundy5
Dec 12, 2010 04:04 PM
Dunf2k9
Jun 14, 2009 03:10 AM
Act of God
Feb 18, 2009 10:05 PM
Argetni
May 29, 2008 07:58 AM
nees1212
Jul 19, 2004 08:58 PM
