Squeaky Belt
Old Dec 1, 2008 | 11:46 AM
malsr's Avatar
Default Squeaky Belt
I think one of my belts is squeaking. After I cold-start the car it starts squeaking but once I get it warmed up and drive it a bit I no longer hear it. Its not that shrill "loose belt" sound...its just a consistent squeaky type of sound that's not even that loud unless you roll down the window. Is this a belt problem or something?????
Old Dec 1, 2008 | 10:48 PM
Check your belts' tension.
If it's not that, check for a bad idler pulley bearing.
Old Dec 2, 2008 | 09:13 AM
malsr's Avatar
If its a bearing would it make the sound all the time, or possibly just when the engine is cold?
Old Dec 2, 2008 | 09:42 AM
It depends, it could be a bad bearing. If you can't localize the noise, take all the belts off and spin the pulleys by hand. You can also try starting the engine with the belts off. If you still hear noise then it is from something related to the timing belt -- the water pump or the tension roller.
Old Dec 2, 2008 | 09:49 AM
ej6buddy's Avatar
belt dressing is your friend.
2005_VP
Dec 26, 2013 06:50 PM
WhiteRabbit1021
Jul 15, 2007 09:33 PM
Spartan21
Oct 14, 2005 06:50 PM
Helpmycivic
Jul 5, 2005 10:53 PM
greenrubber
Apr 29, 2005 12:25 AM
