Starting issue
Searched, but to no avail.
Just picked up a '92 DX sedan for a daily beater. Runs fabulous, but it's difficult to start. It cranks healthy and everything, but in order for it to run you must hold the key for a couple seconds after the initial fire and give it a little gas, otherwise it will immediately die. What might cause this? From what I was told, most of the sensors around the engine bay have been replaced within the last couple years, as was the starter and plugs/wires/dist. cap and rotor. Thanks in advance! |
When you turn the ignition key to ON (position II), does the CEL stay ON or does it turn ON and then OFF after a few seconds?
When you turn the ignition key to ON (position II), do you immediately hear the low humming sound of fuel pump priming for about 2 seconds around the fuel tank in the rear? Do you have the starting problem regardless of whether the engine is cold or hot? |
CEL turns off
Fuel pump is operative Has the issue regardless of temperature |
1 Attachment(s)
If the fuel pump properly primes even prior to a hard start, then I'd recommend that you next focus on the distributor. You might have a failing coil or igniter unit. Start by opening the distributor and carefully inspecting the coil and igniter unit for damage and the wire connections for corrosion or looseness. Also double check the contact points of the rotor and distributor cap while they are disassembled.
Attachment 23369 |
3 Attachment(s)
Additional thoughts:
If the distributor seems fine, then: 1) Replace the fuel filter ($20) 2) Clean the IACV/EACV on the throttle body (see forum DIY section). Attachment 23366 Attachment 23367 Attachment 23368 |
Once started, does it always run properly?
My bet is on the IACV, or the fast idle valve. Both of those should be wide open to let air into the intake when it is cold. The fact that you have to open the throttle manually suggests that it's not getting enough air. Also check your spark timing, that could make it hard to start. That's a routine thing that should be checked anyway anytime you buy a used Civic. |
Originally Posted by mk378
(Post 609125)
My bet is on the IACV, or the fast idle valve. Both of those should be wide open to let air into the intake when it is cold. The fact that you have to open the throttle manually suggests that it's not getting enough air. Also check your spark timing, that could make it hard to start. That's a routine thing that should be checked anyway anytime you buy a used Civic. Noticed this morning that it will start right up immediately after being driven for a little bit (~1.5mi). Let it sit for 5-10 minutes and it becomes difficult again. |
1 Attachment(s)
Originally Posted by DubtecV2
(Post 609126)
Yes, it always runs great once started.
Noticed this morning that it will start right up immediately after being driven for a little bit (~1.5mi). Let it sit for 5-10 minutes and it becomes difficult again. Attachment 23364 |
Ok, scratch the temperature making a difference. This evening after work the engine was dead cold and fired right up..
What I did was allow the fuel pump to prime the system three times. This means the pump is going south, yes? Or could it just be the filter... |
1 Attachment(s)
First make sure that the fuel pump always primes when you have the hard starting problem. Regardless, replace the fuel filter as it is cheap and easy. If that doesn't fix the problem, then measure the fuel pressure:
Attachment 23351 |
| All times are GMT -8. The time now is 11:11 PM. |
