Starting issue
Old Dec 8, 2008 | 06:09 PM
DubtecV2's Avatar
Messing with it some more and found that the fuel pump doesn't always prime. But, the starting issue is still present when it does prime. Tried priming it three times as I did in my last post...this time it still wouldn't start.
I'm thinking a new fuel pump is in my future (along with filter, of course).
Old Dec 8, 2008 | 06:33 PM
You might also want to consider the main relay, which supplies power to the fuel pump. Bad main relays are more common than bad fuel pumps. The main relay is located to the right of the glove box.
Old Dec 8, 2008 | 07:49 PM
DubtecV2's Avatar
Alright, so the pump not always priming may be a bad main relay. Check.
The engine not always starting (even after fuel system primed) could be fuel filter, IACV and/or fast idle valve.
Any other suggestions?
Old Dec 8, 2008 | 07:56 PM
All could possibly point to a bad main relay. You could try resoldering it:
http://www.tegger.com/hondafaq/mainr...mainrelay.html
http://www.marklamond.co.uk/tech-hon...main-relay.htm
Old Dec 8, 2008 | 08:05 PM
After thought -- The problem could also possibly be the ignition switch. This might be evident if the dash lights turn OFF at key position II when the engine won't stay running.
Old Dec 8, 2008 | 08:16 PM
DubtecV2's Avatar
This, too, has happened from time to time. I think I'll focus on the other possibilities first, though. Even if they aren't the cause, it wouldn't hurt to clean/replace!
Old Dec 8, 2008 | 08:20 PM
Alright. Please post any updates so that we can learn from your experience.
Old Dec 10, 2008 | 03:10 PM
DubtecV2's Avatar
Well, I haven't had any starting issue since my last post (typical...). I went ahead and replaced the Main Relay. Replacing the fuel filter (and spark plugs) tonight. Ordered all the gaskets and o-rings for the EACV and Fast Idle Valve. When those come in I'll clean both valves well.
Hope for the best!
Old Dec 10, 2008 | 03:28 PM
I think it was most definitely your main relay. I had the same exact problem, took apart my main relay and re-soldered its connections, and haven't had the problem since.
Old Dec 20, 2008 | 10:49 PM
DubtecV2's Avatar
11 days later....
Starting problem, for the most part, has been resolved. It still doesn't start on the first try from time to time, but I have a feeling that it's a loose ignition switch (when it dies, err doesn't start, none of the dash lights come on unless I turn the key back a tiny bit). It always starts the second try, though, and without aid of the gas pedal. I'll bet I just hold the key that much longer on the 2nd attempts, allowing it to start.
On a second note, today I cleaned and replaced gaskets for the EACV and FIV (EACV screen was NASTY). May just be in my head, but the car seems to run smoother, be easier to start, and maybe even a little peppier off-idle. We'll see if this has an effect on my stating issue.
On a third note, I knew my distributor o-ring was leaking (have one on order), but I didn't know that oil could reach inside the distributor cap and get caked onto the terminals. Two were partially caked with oil, one was completely black. Once I get the o-ring installed I'll replace the cap/rotor/wires...I wonder how much better it'll run considering it runs pretty well now.
