Stripped Thermostat Housing Threads
Old Jan 19, 2013 | 09:39 PM
Vlady Dadi's Avatar
Default Stripped Thermostat Housing Threads
The bolt in my Thermostat housing was over tightened, now the threads in the housing are stripped. Is there a way to fix this? I have a 2004 Honda Civic Lx sedan.
Old Jan 20, 2013 | 06:55 AM
You could pick up a thermostat housing and swap that, or you can drill our the holes and tap it to whatever you would like.
Old Dec 30, 2013 | 10:10 PM
Vlady Dadi's Avatar
The domed part of the thermostat housing is fine. I'm having problems with the rear part of the housing that is connected to the engine block. Should I tap it or is there a replacement for that part?
Old Dec 31, 2013 | 04:55 AM
Honda Automotive Parts
Part #8. You can probably find a used one locally.
Old Dec 31, 2013 | 08:27 AM
TiggerDX's Avatar
Replacing the part might be cheaper, but I have had excellent luck using Helicoil to repair stripped threads.
www.helicoil.com.sg
Old Dec 31, 2013 | 02:10 PM
GeeIWon's Avatar
jockellis
Oct 2, 2014 03:46 PM
Phalen
Aug 1, 2011 08:36 PM
cmfmets
Nov 29, 2007 08:18 AM
Flybye
Dec 31, 2006 12:41 PM
scottk
Jan 10, 2005 09:34 PM
