Stumbling/sputtering problems at highway speeds
Old May 25, 2011 | 07:39 PM
Infinitrium's Avatar
Default Stumbling/sputtering problems at highway speeds
My 98 EX (Canadian) has been having some stumbling/sputtering problems that only seem to occur at highway speeds after the car has warmed up. When it happens, it feels like the enginee is starving for gas. It'll sputter for 5-10 seconds, then jump back to life, then sputter again a few seconds later. It only seems to act up on the highway, around town it feels fine. The only code present is a P0420. I replaced the fuel filter and that didn't help. I swapped the coil and igniter with ones from a junkyard and that didn't help either. The spark plugs are less than a month old. The cap and rotor are about a year old. The oxygen sensor was replaced a week ago. I'm leaning towards a fuel pump issue. I had a 96 2.4 Stratus that did something similar and in that case, it turned out the fuel pump was bad. Do any of you think my Civic's fuel pump could be the cause of the problem?
Old May 27, 2011 | 10:01 AM
...anyone?
Old May 29, 2011 | 06:45 PM
Mcgarvie's Avatar
fuel pump is a cause of it, but my car just had the same problem 2 days ago, it only did it when it warmed up, turned out it was my 4 month old rotor cap.
Old May 30, 2011 | 06:06 AM
norcoshore's Avatar
try a different gas
Old May 30, 2011 | 07:47 PM
I got my Ultragauge today and hooked it up, then did a little cruising to see what it could tell me. I noticed that when the car starts doing those little sputtering episodes, the short term fuel trim goes way negative, almost to -30 and the oxygen sensor voltage goes to 1.275. I guess what that tells me is that for whatever reason the car suddenly senses it's running way lean and needs to massively enrichen the mixture. The only reason I can think of for why it goes massively lean all at once is that fuel flow is reduced by a large amount, like by a failing fuel pump...at least that's the only thing that makes sense to me. I'm going to order a cheap fuel pump off eBay and install it when it comes it and see if it fixes the problem
Old May 30, 2011 | 08:46 PM
conceptualpolymer's Avatar
How about a bad fuel injector?
tl351698
Dec 1, 2013 12:40 PM
r3yalsrats
Mar 22, 2013 08:30 PM
imkimmy
Jan 22, 2008 08:12 PM
NickF829
Dec 28, 2006 06:53 AM
jay weidner
May 31, 2005 10:40 AM
