synthetics oil?
I just changed my oil from conventional to penzoil platinum synethics. Is this ok to switch to the synthetic like that? and am i allowed to ever go back to conventional?
RE: synthetics oil?
What is the milage on your car? the less the better but I allways suggest a synthetic blend over full synthetic for a car that started out on conventional oil
RE: synthetics oil?
You can switch back and forth any time you like. However, the common consensus is that if you have high miles on the vehicle then the synthetic is more likely to leak through seals that are marginal.
