tail light not working?
Old Nov 15, 2006 | 10:31 PM
89redcivic's Avatar
Default tail light not working?
when step on the brake the light doesn't light up? night light work, signal light work. only brake. checked wire, all fuse not blown. what else can cause this? any help will be thank.
Old Nov 15, 2006 | 10:38 PM
Misha's Avatar
Default RE: tail light not working?
Did you check the switch itself? And the bulbs, btw.
Old Nov 16, 2006 | 07:05 AM
luisynayan's Avatar
+1 on checking the bulbs. I suggest checking the wiring again. I had the exact same problem in the past, ends up there was a cut wire that needed splicing and reconnecting...
Old Nov 16, 2006 | 05:56 PM
89redcivic's Avatar
bolbs are good, wire tested, no positive coming. negitive work?
Old Nov 16, 2006 | 06:09 PM
Misha's Avatar
Not sure what you meant by "negative work". Did you check the switch itself?
Old Nov 18, 2006 | 11:32 PM
89redcivic's Avatar
what switch?
Old Nov 18, 2006 | 11:46 PM
Misha's Avatar
Brake light switch. located at the brake pedal, up under the dash
Fng
Oct 21, 2012 05:31 PM
gunaa
Oct 22, 2009 11:36 AM
scottjreid
Oct 5, 2007 08:51 PM
chrisroug
Oct 2, 2006 11:36 AM
derekdunham
Nov 20, 2005 10:30 AM
