Thermostat and ECT switch replacement
Old Jul 7, 2012 | 03:50 PM
Ska-T's Avatar
Default Thermostat and ECT switch replacement
When installing the thermostat is there any downside to using HondaBond HT? The shop manual procedure doesn't mention sealant, but a quick search of these forums and the DIY indicate that some people use it.
Is it a good idea (or too OCD) to change out the engine coolant temperature (ECT) switch at regular intervals like the thermostat, or should I wait until it fails? My '96 Civic has just over 100K mi.
Old Jul 7, 2012 | 04:51 PM
I made the DIY I believe. Adding sealant is not necessary. I added it in after being PM'd saying it would be a good idea. Honda-bond would be fine though.
Replacing the temp sensor is not needed unless there is a failure.
Old Jul 8, 2012 | 11:40 AM
Ska-T's Avatar
Thanks so much for the quick and informative reply.
-Scott
seahorse12
Apr 1, 2012 01:47 PM
UnicornJuices
Jun 11, 2011 06:03 PM
UnicornJuices
Jun 4, 2011 06:44 PM
Ska-T
May 27, 2010 09:32 PM
cvcrcr99
Routine Maintenance DIYs
Feb 23, 2010 06:06 PM
