Throttle position sensor
Old Apr 17, 2006 | 06:59 PM
Belmont's Avatar
Default Throttle position sensor
My buddy's got a 99 civic ex. Lately its been bogging down and we took it to the honda dealership said it was his throttle body position sensor. They said he would have to replace the whole throttle body. They said it would run him around 900 bucks without labor. Any input on just replacing the sensor or should he really replace the whole throttle body?
Old Apr 17, 2006 | 07:09 PM
b8teen's Avatar
Default RE: Throttle position sensor
just go to a auto dismantler, i had the same problem, it cost me 100.00 and it was fine. you cannot change just the sensor because it is rivited onto the t.b
good luck
Old Apr 17, 2006 | 08:27 PM
civicexracer's Avatar
might be able to buy a new tb on ebay that comes with all the sensors, i think ive seen a few like that
Old Apr 17, 2006 | 10:57 PM
AgentofDarkness's Avatar
You sure that the TPS is actually bad? Sometimes the techs don't know what they are doing, so i'm always a little skeptical especially if they don't explain to you how they know something is bad. $800 to change a TPS is way too expensive, you could change the TB yourself for a lot cheaper. You could even get a bigger TB a pick up a HP or 2.
Old Apr 18, 2006 | 02:59 AM
Marty's Avatar
You can take a TPS out. The things that hold them in are screws they just do not have a head for a wrench or a screw driver to fit into. Take a dremel and slice a lil place in it to use a flat tip screw driver and screw them out. you will need to calibrate the new TPS though.
4.5v at WOT
1.5v at closed throttle
Check ebay for a TPS though.
Old Apr 18, 2006 | 03:23 AM
Kappa22's Avatar
ORIGINAL: Marty
4.5v at WOT
He scores! No really, good call.
$900 for a TB is rape.
Old Apr 18, 2006 | 03:27 AM
Marty's Avatar
I had the same thing happen to me and a $500 quote from the dealer for a tb I was like f**k that
Old Apr 18, 2006 | 07:57 AM
ORIGINAL: Kappa22
[sm=icon_rofl.gif]
...Good call Marty, I never would have thought to do that.
Old Apr 18, 2006 | 02:37 PM
Belmont's Avatar
Thanks guys I dont know anything about the 6thgens. So ya'll saved my freind a lot of money.
EightyNineDX
Dec 5, 2012 04:06 AM
aree
May 8, 2007 07:00 AM
darkneck
Apr 24, 2007 06:44 AM
nightrider46
13
Sep 29, 2006 10:00 AM
pbrooks259
Oct 3, 2005 11:06 AM
