Throttle Position Sensor
Old Feb 11, 2009 | 08:16 PM
rags2richs's Avatar
Question Throttle Position Sensor
I need to replace my TPS because its sending my idle hay wire but I cant figure out how it is supposed to be removed there is two screws that are not really screws. My car is a 97 EX 5 speed if anyone has changed theirs or knows how its done could you please throw me a lifeline or maybe a DIY link. Thanks yall
Old Feb 11, 2009 | 08:23 PM
Obviously, the TPS was not designed to be replaced alone. The service manual states that the whole throttle body must be replaced. Nonetheless, I have read that some individuals use a Dremel tool to score a straight line groove into the bolt heads and then simply remove the bolts with a screwdriver.
Old Feb 12, 2009 | 06:08 AM
RonJ speaks the truth, dremel is the way to go.
However, if you do not have a dremel, you can do what I did... Pull the entire throttle body off, and clamp it to a table. Then, carefully, use a hacksaw to cut the straight line into the screw heads.
Remember, when you attach the new TPS, it MUST be calibrated to work correctly.
Old Mar 4, 2009 | 04:06 PM
bcrichguitars's Avatar
How do you remove the 4 bolts holding the throttle body to the intake? Neither side has a head on it, just nuts on the TB side. How do I remove these studs?
Old Mar 4, 2009 | 04:21 PM
Why do you want to remove the bolts? Maybe they just hammer out like wheel studs do?
Old Mar 4, 2009 | 05:40 PM
You just take the nuts off, and remove the throttle body. The studs will stay in the main manifold part.
Old Mar 5, 2009 | 10:21 PM
I just seen that in the picture, thanks.
aree
May 8, 2007 07:00 AM
darkneck
Apr 24, 2007 06:44 AM
nightrider46
13
Sep 29, 2006 10:00 AM
Belmont
Apr 18, 2006 02:37 PM
pbrooks259
Oct 3, 2005 11:06 AM
