Throttle Position sensor Location ??
OK. i see now 2 listings in my post of the same. and that was a cut copy and paste from the topic at the top of this section.
I agree with Agent, as far as i know the tps is not sold separately (but i would check around - just seems like it should be). I had a problem with mine once, and went to a local honda/acura repair shop and one of the guys there said i could just get one off of an old throttle body in the back of the place. i left it go and the problem cleared up.
BUT, you should have a CEL (check engine light) on if your tps is defective. SO, is your CEL on ??
MPFI = Multi Port Fuel Injection. I'm almost positive that all the civic engines after 92 are MPFI. I know for a fact that a B16 from a 95 Del Sol (thats the year i happened to check, should be the same for all the B16 del sols from 92-95) has a throttle position sensor. The reason why the TPS might not be sold seperatly is b/c it is riveted (or permanatly attached some other way) to the TPS.
darkneck
Apr 24, 2007 06:44 AM
pbrooks259
Oct 3, 2005 11:06 AM
