tps
well the computer said that the o2 circuit was low and i already replaced the first one, so now ill replace the other one.....and the guy at checkers told me that the other code that it was throwing was for the tps, or said that i should change the tps.
Just b/c the computer says that the O2 sensor is giving a low reading, it doesn't mean that the O2 sensor is bad. If you cut the wire to the O2 sensor (or if there is an open O2 sensor circuit) it would throw the same code. What is the codes that it is giving you? Generally we can help you alot easier and better if you tell us the codes.
