transmission
Noise from inside the tranny would go away when you push the clutch pedal down. Noise from the throwout bearing would only occur with the clutch pedal pressed down. If you have a whirring/grinding noise in neutral that's just the bearings on the transmission input shaft. It's inside the transmission but you can open it up and change those rather simply without needing a whole transmission.
ORIGINAL: dulas101
its a manual, and yea im positive. my second gear pops out of gear when i coast around a turn in gear, and thats if i can get into gear. usually ill hold the clutch all the way in and ill have to slam the stick back into second just to get it into gear or else it just grinds away even more than it already is.
"Poping out of gear" can also be caused by the shift linkage or faulty motor mounts that let the engine move and pull on the linkage. If it grinds when you try to shift to reverse with the engine running and the car fully stopped, that means the clutch doesn't disengage fully.
slideman99
Aug 3, 2004 06:10 PM
Civic95Blue
Jul 29, 2004 10:09 PM
