Transmission fluid question
went to honda today and bought 2 quarts of manual tranny fluid. changed the fluid which calls for 1.9 quarts. poured it in till it started pouring out a little. my question is when i stuck my finger in the filler hole i couldnt feel any fluid, does this mean it needed more? i only bought 2 quarts so i didnt have anymore to add, should i have felt it at the filler hole end?
i couldnt feel any like where the threads were, i stuck a screwdriver in and there seemed to be about an inch in before the fluid left a mark on it, do it need more? i mean i did add the required amount.
no i just used a funnel and a long hose. i kept adding till it started to pour out a bit which was my full 2 quarts, but after that it just wasnt that noticable from the filler hole. should i be ok?
if worried about it just add alittle more... if it sjust alittle short i dont see it being a problem....
but if ya got some free time..... why not add the fluid to top it off...
But seriously, you are suppose to feel it.
