transmission problem
Old Jun 12, 2008 | 04:23 AM
impmouse's Avatar
Default transmission problem
new to this form ,,, have a 96 civic hatch with an automactic ,1.6L, all stock, transmission shifts hard in 2nd and 3rd gears ,,,, transmission does not slip tq locks ,, chaged the fiuld three times , changed the linier shift solenoid , changed the computer , changed the solenoid pack on top of the transmisson,, and checked the ohm load on the solenoid pack on the side of the transmission ,check out at 31 ohms and thats what all the other ones check out at ,,, changed the rear motor mount to ,could it be oh it down shifts from 3rd to 2nd very hard ,,, got the car because of gas prices but i'm about to buirn it to the ground and just keep driving my diesel truck .....changed the fuild with dex merc and used 2 bottles of red lube ,,, is honda transmission fluid that great ?
any help would be great
thanks
Old Jun 12, 2008 | 05:51 AM
Default RE: transmission problem
Honda transmission fluid is essential. It's completely different from generic fluid.
Old Jun 12, 2008 | 08:44 AM
When I had my old civic with an automatic transmission my manual said Honda fluid or Dexron II fluid. I used synthetic B&M Trick Shift ATF and it never gave me any problems.
Old Jun 12, 2008 | 10:18 AM
impmouse's Avatar
ok i will give honda fuild a try and see what happens ,,,, if that does not work any ideas what else it could be ,,, thanks
Old Jun 12, 2008 | 12:18 PM
darksideofjae
May 31, 2005 06:11 PM
wohnny
Apr 14, 2005 10:24 AM
at22
Jan 25, 2005 10:36 PM
tanksOnFire
Jan 8, 2005 03:38 PM
tanksOnFire
