tricks to put back fuel pump
Old Nov 9, 2007 | 09:57 AM
Default RE: tricks to put back fuel pump?
(In response to headacheforhonda) I hope I do not offend you. I am just having difficulties understanding your problem. As you didn't need a mechanic's trick to remove the pump, why do you think a trick is needed for the reverse action.
Old Nov 9, 2007 | 10:01 AM
Civic Si 00's Avatar
You are funny Ron J....So what do you think is it the same procedure for my gas tank. I just want to know because on the future I don't want to post a thread "How do I remove my fuel pump".
I will drive the Si today in a while and hope it was that stupid bolt on my distributor....[:@]
Old Nov 9, 2007 | 10:44 AM
headacheforhonda's Avatar
In response to Ron J. As I said, it's so easy to took it out, but I spent 2 hours with different tries wothout putting the new one to the right position. That remind me to ask whether there might be a trick to put a new one in.
Now What should I do with the tank full of gas opening? obvious I can't move the car, can't tow the car? Any safty procedure if I can't put this dam pump bakc on?
Old Nov 9, 2007 | 10:54 AM
Take the bad pump off of the top cover assembly and use that cover with no pump to close up the hole. I agree to walk away from it for a while, and when the gas fumes have cleared your head, try it again. I suspect the trick is to come in at a particular angle in the first place.
You can drain most of the gas out with the drain bolt in the bottom of the tank.
Old Nov 9, 2007 | 11:06 AM
mk378
Thanks you much. You came up with an excellent idea to just cover up with the old cover. I am more than three hrs with this now. I do feel a little dizzy with the gas vapor now. Wish the gas not too toxic. I take your advice and am going away from my car for a long while, then come back to see if I can put it right in.
Thanks and have a good weekend in case I stop postting for now.
Old Nov 9, 2007 | 04:32 PM
Civic Si 00: You are funny Ron J....So what do you think is it the same procedure for my gas tank. I just want to know because on the future I don't want to post a thread "How do I remove my fuel pump".
The picture shows that replacing the fuel pump on your 2000 Civic is similar or identical. Good luck with the test drive.
[IMG]local://upfiles/25538/96A5CDF650F8442C95D34146A83A2924.jpg[/IMG]
flcb7
Nov 3, 2010 05:21 PM
wkhan69
Aug 9, 2009 10:08 AM
headacheforhonda
Nov 13, 2007 05:07 PM
seriously_furious
Aug 14, 2006 08:49 PM
buffman
Jan 28, 2005 09:38 AM
