Trouble removing crankshaft pulley bolt, damaged pulley
Old Jan 22, 2009 | 09:31 PM
Originally Posted by flattire
in other words, does the crankshaft sprocket have index marks on it?
yes
the sprocket has a notch, and the oil pump has a notch too. you line up the two notches and the crank is at TDC
then set cam to TDC using the cam gear "UP" marking and the notches on the sides
Old Jan 23, 2009 | 11:41 PM
flattire's Avatar
Karrde, your recommendations were bang on. I grabbed a couple high strength 1/2" bolts and put them in the pulley, and used a big bar to keep the pulley from turning. I had a 2' breaker bar with a 1' cheater on it, with 2x10" extensions like you said. Holy ****, i had to use almost my whole bodyweight and when the nut finally broke, it sent a shockwave up my arm and it almost felt numb for a minute.
Got the job done. Back togerther everythig went, and i turned to motor over a few dozen times with the starter, rechecked the mechanical timing and it lined up. Total job time approx 6 hours. I see why shops charge so much now.
Old Jan 24, 2009 | 05:09 AM
project5k's Avatar
i went through this exact same crap when i did mine the first time, stubborn bolt and broken pulley. seems to be a common theme on these...
whitecivicex
21
Dec 5, 2011 04:29 PM
jds62f
Apr 25, 2010 06:01 AM
Shovhed1
Mar 17, 2008 12:58 PM
Basil
Aug 30, 2007 09:34 AM
baker7598
Jan 27, 2007 06:49 AM
