Turbo B16A only 10 lbs of boost how much needs to be upgraded? Internally?
I just kind of want to know if I have to really change much with the motor besides fuel pump injectors and ecu? I know how to do this just not what needs to be done to have a reliable B16B for everyday driving.
you have a b16a or b16b?? but if you have the b16a its good to get low compression pistons and rings, and of course the upgrading the fuel pump and injectors is a must and as for the ecu i would get a p28 ecu and have it chipped and tuned.
I'm guessing you're getting a smaller sized turbo. On 10psi you should be safe with stock internals as long as a compression test indicates that the engine is in good health.
However, as munkeewrench23 noted, you still need to upgrade your fuel system by getting a high flow fuel pump such as Walbro 255LPH, some bigger injectors, and a good tune.
A t-3 or t-28 Im fabbing the kit. It is B16A typo on the B16B
