Turning over, but not starting
Old Nov 24, 2007 | 12:40 PM
weez's Avatar
Default Turning over, but not starting
My '92 sedan turns over and starts briefly but dies seconds later. This
started yesterday morning, few months ago I had the alternator replaced
and had no problems until now, any advice?
Old Nov 24, 2007 | 12:58 PM
Default RE: Turning over, but not starting
If the Check Engine Light (CEL) is ON, the code(s) that you can retrieve might be informative (see picture). Otherwise, you should start by determining whether spark is detected at each plug. If you have spark, then consider problems with fuel getting to the cylinders, such as a clogged fuel filter, faulty fuel pump, or bad main relay circuit.
[IMG]local://upfiles/25538/A0FC386331574B68A91102BC70382740.jpg[/IMG]
Old Nov 24, 2007 | 01:04 PM
civic_burns_all's Avatar
check the starter solenoid
HondaTrex
Feb 5, 2009 04:51 PM
ClinDiesel
Sep 30, 2007 10:10 AM
Azeluk
Sep 1, 2007 02:14 AM
HelpMyHonda
Apr 29, 2007 06:07 PM
ryank327
May 28, 2006 09:09 AM
