V-Tec not engaging
I have changed the oil, not leaking oil so it's good there. I pulled the solenoid hooked it up to 12Volts it clicks test the wire from harness it lights up when hooked to negative post, solenoid lights up if I put the light on the positive post. Any ideas on how to trace where it might be grounding out?
do you have any CELs? How did you get vtec on you HX? swap?
VTEC-e I would assume Dano. He has the gas saving model
V-Tec
The swap was done before I bought the car. I found the oil filter was loose about half a turn and now it's V-Tec Heaven.:cool:
