V-Tec not engaging
Old Aug 25, 2012 | 12:21 PM
my97civichx's Avatar
Default V-Tec not engaging
I have changed the oil, not leaking oil so it's good there. I pulled the solenoid hooked it up to 12Volts it clicks test the wire from harness it lights up when hooked to negative post, solenoid lights up if I put the light on the positive post. Any ideas on how to trace where it might be grounding out?
Old Aug 27, 2012 | 05:18 PM
danomatic93's Avatar
June 2010 ROTM
do you have any CELs? How did you get vtec on you HX? swap?
Old Aug 28, 2012 | 06:43 AM
VTEC-e I would assume Dano. He has the gas saving model
Old Aug 30, 2012 | 07:46 AM
Default V-Tec
The swap was done before I bought the car. I found the oil filter was loose about half a turn and now it's V-Tec Heaven.
HondaEGcoupe
Aug 9, 2009 10:12 AM
Kenneth Ames
20
Feb 17, 2007 10:39 AM
rex.m.h
Feb 23, 2006 03:09 PM
mhouse
Jul 20, 2005 12:50 AM
AOL.COM
Apr 24, 2005 12:07 AM
