valve cover
:( I just changed my valve cover gaskets cause I had oil in my spark plugs. but when I tightend the 4 bolts of the valve cover I broke one. does anyone know if that can be replaced. I have a 91 4 door lx. Its the one on the driver side closest to the front of the car.
RE: valve cover
sure they can be replaced, they're held in there by RUBBER seals...just pull on it with a wisegrip
RE: valve cover
whe n you pull off the valve cover the threaded bolts that stick up and go thru the cover to tighten the cover down. the threaded part is what broke. It looked like it was part of the engine.
RE: valve cover
picture?
RE: valve cover
Oh dear, that dont sound good. Well, you can alwyas mix a little JB weld and stick it in there but you wond really be able to get that sucker open again :D
RE: valve cover
ORIGINAL: brolo :( I just changed my valve cover gaskets cause I had oil in my spark plugs. but when I tightend the 4 bolts of the valve cover I broke one. |
RE: valve cover
Man, some people use torque wrenches for everything...
But yeah, you'll be able to unscrew the stud with a good set of vice grips and some patience. |
RE: valve cover
ORIGINAL: Kappa22 Man, some people use torque wrenches for everything... |
RE: valve cover
I know... I'm just givin' you a hard time.
RE: valve cover
ORIGINAL: Kappa22 I know... I'm just givin' you a hard time. |
