valve cover
Old Oct 23, 2005 | 07:38 PM
brolo's Avatar
Default valve cover
I just changed my valve cover gaskets cause I had oil in my spark plugs. but when I tightend the 4 bolts of the valve cover I broke one. does anyone know if that can be replaced. I have a 91 4 door lx. Its the one on the driver side closest to the front of the car.
Old Oct 23, 2005 | 08:16 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: valve cover
sure they can be replaced, they're held in there by RUBBER seals...just pull on it with a wisegrip
Old Oct 23, 2005 | 08:34 PM
brolo's Avatar
whe n you pull off the valve cover the threaded bolts that stick up and go thru the cover to tighten the cover down. the threaded part is what broke. It looked like it was part of the engine.
Old Oct 23, 2005 | 09:01 PM
Cat Fuсker
picture?
Old Oct 23, 2005 | 10:33 PM
Remmy's Avatar
Oh dear, that dont sound good. Well, you can alwyas mix a little JB weld and stick it in there but you wond really be able to get that sucker open again
Old Oct 24, 2005 | 09:35 AM
ngoti 8tor's Avatar
ORIGINAL: brolo
That's why they say to use a torque wrench. You'll have to take your valve cover off again and try putting a big "vise-grip" pliar on the broken stud as tight as possible and see if you can unscrew it.
Old Oct 24, 2005 | 12:01 PM
Kappa22's Avatar
Man, some people use torque wrenches for everything...
But yeah, you'll be able to unscrew the stud with a good set of vice grips and some patience.
Old Oct 24, 2005 | 12:29 PM
ngoti 8tor's Avatar
ORIGINAL: Kappa22
If that was directed towards me, I figure the reason he broke the stud was that he was probably over tightening the thing. I mentioned torque wrench because it can be a handy tool for a novice and prevent over tightening.
Old Oct 24, 2005 | 12:54 PM
Kappa22's Avatar
I know... I'm just givin' you a hard time.
Old Oct 24, 2005 | 01:06 PM
ngoti 8tor's Avatar
ORIGINAL: Kappa22
hehehe........8,653,497 others on here are giving me a hard time and now you start..........lol
