Vapor leakage. Help please!!!
Old Sep 7, 2005 | 10:11 AM
Hulk's Avatar
Default Vapor leakage. Help please!!!
I have some vapor leakage coming out fromt he reservoir underneath my radiator. Comes out as vapor leakage, and starts to over heat my car. Has anyone ever had this problem??
help!!!
Old Sep 7, 2005 | 10:58 AM
Hulk's Avatar
Default RE: Vapor leakage. Help please!!!
its also a 92 CX btw
Old Sep 7, 2005 | 11:31 AM
97CivicEX's Avatar
ORIGINAL: Hulk
help!!!
What do you mean by vapor leakage? Do you mean steam? If so then you have a small crack that will leak only when under pressure. Have your radiator looked at by a mechanic.
Old Sep 7, 2005 | 11:41 AM
Hulk's Avatar
yeah steam.
is that something i could fix by myself?
Old Sep 7, 2005 | 11:53 AM
97CivicEX's Avatar
not a cracked radiator unless you know how to weld. That is also assuming the crack is on metal part of the radiator, but it sounds to me like the crack is on the plastic part way at the bottom right? I would take it to a radiator shop, not a regular shop, but a specialized radiator shop. Ask them if the radiator you have can be fixed. Show them the place it is leaking. If they say yes ask them how much would it cost if you do the removal and installation of the radiator. If it can't be repaired I would search for a replacement radiator online. I bought one for my car for much less than most shops were offering them. Good luck.
sexypants
Mar 13, 2010 07:39 AM
Infinitrium
Mar 7, 2010 07:21 PM
marmot21
Apr 27, 2007 09:26 PM
D16z6
Oct 14, 2004 07:25 PM
