Vibration in 1st gear
Old May 9, 2010 | 07:52 AM
Johnny Appleseed's Avatar
Question Vibration in 1st gear
When ever moving from a stop the entire cabin shakes, is there anyway to eliminate or reduce this vibration?
Old May 9, 2010 | 09:12 AM
Check the motor mounts and axles. Another possibility is clutch chatter due to clutch wear.
Old May 9, 2010 | 09:19 AM
Your most likely right about the clutch wear, it's a 1998 manual civic. Any tips on checking the Mounts and Axles?
Old May 9, 2010 | 01:39 PM
Get rolling in first gear, let the clutch off fully then alternately give it gas and abruptly let go of the gas pedal. If there's banging from under the hood, probably bad mounts. If the car behaves OK in that test but shakes when you have the clutch partway out, it's the clutch.
Juans_MX3
Apr 9, 2010 05:37 AM
andybuck711
Mar 3, 2010 07:14 PM
MasterJT
May 18, 2008 05:37 PM
Apostle
Jan 7, 2008 03:30 PM
Tomo!
Apr 28, 2006 02:02 PM
