VSS(vehicle speed sensor)
Old Nov 28, 2005 | 10:45 PM
95CIVICUS's Avatar
Default VSS(vehicle speed sensor)
Ok so i'm pullin a code on my comp. b/c my speedometer doesnt work. so i finally dcide i want to know how fast im going. (got pulled over). anywho. I pll the ocde form the book and it tells me VSS. So i call the honda dealership and they ask me which one it is. THewy say that ther is two sensors one in the instrument panel and one on the transmission anyone everheard this before? my name is what car i have. I have never heard of this before. b/c i cant get the code reader to tell me which one it is,. and i dont wanna just throw **** at it. to get the problem fixed b/c the seensors and in excess of 100/. help me
Old Nov 28, 2005 | 10:52 PM
97CivicEX's Avatar
Default RE: VSS(vehicle speed sensor)
autozone normally will read the code for you. you said you pulled the code already? What was the exact code number? P????
Old Nov 29, 2005 | 04:57 PM
Crimson Fox's Avatar
Well, considering that a sensor in your instrument panel can't really measure your speed, I would guess that the problem is likely with the sensor in the tranny. Good luck with your issue.
Nick
Old Nov 29, 2005 | 05:02 PM
Sik 6's Avatar
I have the same problem and the solution was that my speedo cable was broke and i needed a new one. They are like $30, from the stealership.
Old Nov 29, 2005 | 08:36 PM
Fiirkan's Avatar
I have a similar issue, except mine works sometimes and the times it doesn't it reads 30kmphno matter how fast i go, i heard it could be the spped senors or a bad connection on the link for the sensor in the engine, but iahevnt fixed it yet. i am hoping to get it fixed when i take the car home during Xmas. Good luck with your BTW
Old Nov 30, 2005 | 12:32 PM
95CIVICUS's Avatar
I fiddled with my sensor last night nd took it out of the tranny. I unplugged the wire from the sensor and cleaned the trminals as well as the sensor itself. I put it back in and guess what. SHIM SHAM BIM BAM BOOM?! It works. i dunni what i did but it worked. oh and now i know how fast im going now. always good to know that i guess.
oneplustwins
Jul 12, 2012 07:24 AM
xalents23
Apr 24, 2008 09:28 AM
inhot
Jul 11, 2006 08:48 PM
ironhurts
Apr 15, 2006 10:43 AM
ironhurts
Feb 9, 2006 12:48 AM
