vtec conversion or engineswap????
Old Jan 23, 2012 | 03:53 AM
stockda9=slowbutfasterthangm6's Avatar
Smile vtec conversion or engineswap????
ok so have recently bought a honda not a civic but ne ways have a b18a1 am looking for a lil more power have found a list to convert it to vtec
-Ls/vtec kit (should come with sandwich plate, tap, 1/8 NPT plug, oil line, dowell pins)
-Vtec head (B16/ITR or GSR)
-Headgasket
-OBD0 to OBD1 ECU jumper harness (optional, but recommended if you want to tune)
-ECU (PW0 or PR3 if your staying OBD0, chipped P28, P30, P61, or P72 if OBD1)
-98-01 B series oil pump (optional but highly recommended)
-Water pump (optional)
-Timing belt (optional)
-Headstuds (optional, but good to have specially if your boosting) but looking into it and cant find any of the parts i need locally is it cheaper and easier to just stick a k series or h22 in it and are there any real hurdles to overcome with a engine swap like wiring harnesses and other suck things like mountings and what not
Old Jan 23, 2012 | 06:24 AM
You need to tune with that motor set-up, so the conversion harness and ECU and probably tuning would be necessary.
Go to honda/acura for the pumps and belts. Just my suggestions. I think a HG should come with the vtec conversion kit. ECU can be found on eBay, or Phearable.net - Electronic Fuel Injection Tuning Solutions - Hondata, Neptune, Crome, Uberdata, Ectune, AEM, Honda Tuning, Widebands, Fuel Pumps, Intercoolers, Turbos, LS/VTEC, ECU Chipping, Chipped Ecus, P28
Head studs are a good idea, in addition to ARP rod bolts, too.
Old Jan 23, 2012 | 11:40 PM
ok but would it be cheaper and easyer to just do an engine swap or going by ur pics there thatd be a no ? lol
Old Jan 24, 2012 | 05:35 AM
Well, it would technically be easier to just do a head swap as opposed to a complete motor swap. The ls/vtec motor you are describing will get you about 170whp/140ish wtq from what I have seen. I have no idea how much this would be costing you.
I would imagine a full GSR swap would be about $2.5k, and you would get the reliability from Honda and see about 160whp/135wtq. You could also go H22 ( ), and see about 175whp/155wtq. These are all stock motors of course. With a basic tune, a 2.5" short ram intake, 2.3" exhaust, and a nice exhaust manifold, and minor tuning, my h22 made 195whp/165wtq.
Figure out what your power goal are first, then see the possibilities on how to get to the power and then pick which way you want to get there depending on price, or what you want to do in general.
Old Jan 24, 2012 | 08:08 AM
Ramyswar's Avatar
Didn't think an h22 could generate around 200whp, nice info.
Old Jan 24, 2012 | 05:58 PM
yer well i live in australia and so far sourcing parts affordably is the problem from building the b18 my parents have a h22a1 in there car and 1 with bent valves in the shed trying to get that outta them but is seeming harder than first imagined :/ lol but thats cause they wanna keep matching numbers will h22 go on the b18 and will it do anything nice for it
Old Jan 24, 2012 | 05:59 PM
the head*
Old Jan 25, 2012 | 05:16 AM
No. H heads are not compatible with B blocks.
Old Jan 31, 2012 | 05:44 PM
ok so so far found a b16 vtec head from wreckers and think they jewish $2200 for just the head thinks this could get expensive
Old Feb 1, 2012 | 06:20 AM
$2200 is more than what a complete B16 should cost. lol Go elsewhere
Scruffy1994
Jun 13, 2015 08:18 PM
Booger
EK Swaps
Aug 9, 2011 10:11 PM
trustdestruction
Jan 29, 2009 12:02 PM
joejoe2007
EG Swaps
Oct 25, 2006 01:16 PM
88civicjordan
Mar 2, 2006 09:12 PM
