VTEC issues
Old Mar 7, 2008 | 02:26 PM
ROFLmao's Avatar
Default VTEC issues
I have a 2002 civic ex 5spd with the D17a2 engine. I bought this car just 3 days ago. The one major thing bugging me is that the "vtec" does not work. I've tried getting a price quote on the repairs for this problem, but the guy kept dodging my questions. Any help? Oh yeah.. when does the timing belt need replacing.
Old Mar 9, 2008 | 12:37 PM
ROFLmao's Avatar
Default RE: VTEC issues
The engine is the 1.7 found in the ex. I really need to know what could have gone wrong.
Old Mar 9, 2008 | 04:32 PM
civic_burns_all's Avatar
what do you mean VTEC does not work? You have VTEC-E. if your VTEC didn't work your car wouldn't even move. Is the VTEC not properly kicking in or something? If so check the VTEC solenoid
Old Mar 9, 2008 | 08:07 PM
cyberx32's Avatar
Timing belt should be changed every 100,000 miles or sooner
Old Mar 9, 2008 | 08:32 PM
Gene J's Avatar
How do you know the VTEC is not working?
Old Mar 10, 2008 | 10:12 AM
ROFLmao's Avatar
From what I understand about the VTEC-E system is that the car activates the second intake valve at a specific rpm to give better power at higher rpms. If this is so then it should give a noticable surge of power. Very much like in my old Contour. Please correct me if I'm wrong.
-And thanks I will check the solenoid.
Old Mar 10, 2008 | 06:32 PM
vertech0's Avatar
i dont know if this has anything to do with it, but im gona put it out there. on mine, the guy that did my last oil change put 2qts more of oil than needed. SOMEHOW it lasted a week befor the check en. light came on. as i searched the fourmes i found that vtec worked off of oil pressure (i dont know if this is true or not) , so i drained the 2 extra qrts out and i hit vtec just fine and so far the chech en. light hasent come back on. not sure if this relates but maybe check your oil?.
Old Mar 11, 2008 | 03:52 AM
s2000gtx's Avatar
yeah vtec work off oil pressure. not enought oil and vtec wont work im not sure about too much oil tho. also sometime your solinoid can go bad but i also herd that they rarly go bad and u have an newer model civic so hopefully u didnt get a manufacture defect one. also ur ecu have something to do with vtec too . i know on m hx i had to change the ecu to another hx one because i was having trouble with it.
Booger
EK Swaps
Aug 9, 2011 10:11 PM
4dr civic type r
May 15, 2011 05:48 AM
reww
Apr 19, 2011 07:46 PM
1quickhatch
Mar 9, 2007 07:25 AM
kcmercedes
EK Swaps
Sep 24, 2004 11:05 PM
