Water dripping from dash?
I was driving today and I noticed water started dripping from behind my glove box down onto my passenger side floor mat. I had the AC on so im assuming its just condensation but I want to make sure this is somewhat normal. Does it sound like anything I should be concerned with?
this happened to my civic before. I would find water on the passenger side carpet whenever i turn on the AC. For some reason it does not happen anymore so i'm not sure what going on there. not sure if this is normal or not, since the problem went away i completely forgot this happen to my car until you posted this thread
K. Im going to just ignore it then and see if it goes away too. I was just worried because on all of my last cars when water leaked onto the floorboard it ended up being the heater core lines breaking. Slightly different location but this is my first Honda so just wanted to be cautious
Thx for the input!
Thx for the input!
ya its the drip drain... it should not drip in your car tho... the drain tube is clogged up.
very simple to fix! pull off the rubber hose that does into the bottom of the black plastic ac ducting and pull it out from the floor... its not secured any way just sitting there.
what commonly happens is dirt and mud clogs up the hose which just makes it build up in the car since it cant drain....
just pull the hose out and run water thru it from your sink or garden hose till it flows freely
and just to be safe use a pen or stick and stick it thru the hole in the ac ducting to ensure nothing from the inside is clogging it. it could have some leafs debri inside it.
the drain hose hole does thru here i believe
very easy!
or if your to lazy sometimes geting a underbody car wash can clean out some of the dirt/mud on the end of the drain hose. its just easier to pull the hose and rinse it out.
and just to be safe use a pen or stick and stick it thru the hole in the ac ducting to ensure nothing from the inside is clogging it. it could have some leafs debri inside it.the drain hose hole does thru here i believe
very easy!
