HondaCivicForum.com
-   -   Weird Brake Light Problem? (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/weird-brake-light-problem-95513/)
Highlighter Jul 13, 2013 02:54 PM
2004 Honda Civic LX 4 Door. When I press brake pedal the left light tail light does not work. I changed bulb but still doesn't work but the right one does. Here is the weird part the bulb does light up when I turn on the left turning signal.
Any suggestions?
mk378 Jul 14, 2013 04:27 AM
This happens because the bulb is not grounded. Check for corrosion of the socket and check the ground wires.
