Weird Noise??? BelT?
I have no clue about mech's at all on a car. anyway i have a 93 civic cx hatchback... I think cx anyway. when i get it to around 5,500 rpms or just when i accelerate fast. When i switch into 2nd gear and then third and such each time it sounds like i have turbo you know the 2-3 second squeek or w/e sounds like air blowing. I think i just have to tighten 1 of the belts i forgot which 1 it would be though? any thoughts?
Glad to see that I am not alone. I have the same exact problem But noone would answer https://www.hondacivicforum.com/m_65047/tm.htm
i have a squeeling problem when running the a/c you might need new blet if its squeels or you might be able to just tighten it just pull on the belt and you should be able to tell if its lose or not by the feel of the other belts
marcin69k
May 25, 2007 04:25 PM
