weird reving
I have a 93 hatch back with a h22a swap. When I start it the engine revs then stops the revs then stops, it does this until I have been driving for like 10 min or so. A buddy of mine said it could be the ECU. If any one can help I would appreciate it.
Thanks |
RE: weird reving
is this only while at a stop or while driving too? it's kinda normal for your rpms to be a little weird at first with a cold start, and then go away. It could be normal, or if it seems abnormal to you it could be a dirty idle air control valve, that is if it's only doing it at idle.
RE: weird reving
1 Attachment(s)
RE: weird reving
If it has always done this since the swap, you may have some mis-matched parts.
RE: weird reving
I've had the car for about a month and it already had the swap. And it only does it while at idle.
RE: weird reving
Sounds like it's your IACV (idle air control valve) or your fast idle valve. Clean them both with carb cleaner and see what happens.
