What does the little spring in the coil do (2000 Civic)?
Old Nov 18, 2013 | 06:39 AM
domzeebomb's Avatar
Default What does the little spring in the coil do (2000 Civic)?
The small spring that you see when you pop the distributor cap off, that sits in the coil? I popped the distributor cap this weekend when I was doing a compression check, and the little spring fell out. I put it back in (I think), but how do I know that it stayed in vs. falling out when I put the cap back on?
What exactly is it's purpose? And how do you ensure that it stays on the little tab on the coil when you put the distributor cap back on?
Thanks
Old Nov 19, 2013 | 10:37 AM
droopy128's Avatar
That spring and pin is to make contact with the distributor rotor, it transfer electric current that give sparks to you spark plug..
Old Nov 20, 2013 | 05:29 PM
domzeebomb's Avatar
Is it supposed to be attached to the coil? Mine fell out, I put it back on the little post inside the coil, but it falls off pretty easily - I had it fall off a couple of times when I was putting the dizzy cap back on.
Old Nov 21, 2013 | 12:17 PM
droopy128's Avatar
That is part of your distributor cap.. you should replace the dizzy cap.
Old Nov 23, 2013 | 09:11 AM
domzeebomb's Avatar
great - thanks
fifteenwindow
May 25, 2014 01:14 PM
spurabad1
Jun 7, 2012 04:26 AM
Hola
Sep 11, 2007 07:17 AM
Lab Rat 21
Jun 18, 2004 02:22 PM
