what rpm to shift?
just got my 96 civic ex, couple weeks ago
i'm having hard time to engage the clutch smoothly
especially at 1st gear, or anytime i up-shift below 3k rpm
have to rev it above 3k rpm, and release the clutch much
slower than any other cars i've driven, in order to have a
smooth engagement
wonder if thats normal for civics, or the clutch is worn?
according to owner's manual recommended shift speeds,
approx 3.1k rpm before upshift, isnt thats a little high? or
civic's torque is really that low?
is it just me, or anyone else experienced the same?
Main thumb rule on Civics; use "high" rpms.. Don't run around with 6-7k but use higher rpm than you would usually do. Using low rpm only wears down the engine more than you have to. 3-4k should be ok, but don't go over 4k if you don't have to. 3k isn't high on a Civic though, so don't worry
