what should i have checked at 100k miles?
i have a Honda extended warranty up to 100k miles on my Civic 05
im currently at 94k miles
my driver side wheel bearing just went out and i had that replaced under warranty
while replacing it, the honda dealer said my compliance bushings are going too, and they volunteered to replace it under warranty as well
what other parts tend to fail about this time that i should have them check before i hit the 100k mark?
(i know im supposed to do my timing belt around this time, but that is not covered under warranty so ill have to do it myself
Believe me, if you ask them to do a complete check, they will find things. After all, they get paid for all warranty work they do. On some of the older Hondas (like mine), the valves should be adjusted every so often. I had mine done at 120,000 miles, but they probably should've been done sooner.
at 100k miles... hmm.. first i would have your eyes checked.. we have a search button up top that will guide you to 50 articles just like this XD
j/k
anyhow, if they want to find stuff wrong, let them, if its under warrenty, you might as well let them replace everything that way you dont have to replace it down the road. the timing belt should be replaced around 150k but you can change it erlyer. just do a full tune up on it. also replace the pcv valve, mitch told me to do that and my car runs 96% better now
thanks mitch!
j/k
thanks mitch!
150k timing belt....... lol
do it around 80-100k i wouldnt trust it anymore than that, and do a water pump.
fuel filter,change trans fluid, check tie rods and ball joints, cv axles, pcv valve
plugs,wires,cap,rotor, clean fuel injectors,
if you can find ANYTHING under warranty... DO IT hell, tell them you hear something that you think you might like to get replaced ha ha...
...... warranty... dam... that must be nice XD
tismouaboi
May 22, 2008 12:04 PM
tismouaboi
May 21, 2008 02:43 PM
cowsgonemadd3
Aug 13, 2006 10:21 PM
tgamer
Jun 27, 2004 06:29 AM
