When Installing Intakes
Old Sep 12, 2006 | 02:08 PM
TheMoogly's Avatar
Default When Installing Intakes
WHy do you have to disconnect the negative on the battery before the install?
Old Sep 12, 2006 | 02:52 PM
windcalmer's Avatar
Default RE: When Installing Intakes
You know, I have no idea. I just always do that beore doing any work on my car. I never thought about it, but now that you bring it up I want to know too.
Old Sep 12, 2006 | 02:55 PM
My04Civic's Avatar
Administrator
read the other post on this subject today
Old Sep 12, 2006 | 07:07 PM
fglaustin's Avatar
are you disconnecting any electrical connectors when removing and installing.
if so, then the advice is correct
Old Sep 13, 2006 | 12:29 AM
windcalmer's Avatar
What other post?
Old Sep 13, 2006 | 05:18 AM
WhtRice's Avatar
Member
Mostly any ASE cert'd guide starts off by saying disconnect the battery, on my old C10 the Chilton's 1st step to changing the fan belt was disconnect the battery, if at anytime you're using a wrench around the battery i.e. changing to cold air by the battery on the firewall and theres a chance you could turn the wrench to a degree where you connect anywhere near the negative terminal to cover their own *** against a law suit theyll say that in the event of you grounding your wrench on the terminal or connector and frying yourself and trying to take them to court for your own stupidity.
Or the same thing where you ground out a positive lead off of the intake, it depends.
Old Sep 13, 2006 | 09:52 AM
volcanomike's Avatar
I also noticed that when i took my intake off to access my throttle body that when i put it back on i seemed to bump something and my check engine light came on, that was with the battery connected. Maybe for that purpose? Now i always disconnect it so i wont have to afterwards ha.
Old Sep 13, 2006 | 07:25 PM
windcalmer's Avatar
Cool. Thats for letting me know.
Old Sep 15, 2006 | 01:52 PM
VTECivic95's Avatar
ORIGINAL: TheMoogly
i didnt do it and im still alive as well is my car lol
TheMoogly
Sep 12, 2006 07:57 PM
mill$civic
Apr 16, 2005 05:05 PM
faceless_civic
Nov 1, 2004 04:49 PM
civic1.5uk
Jul 18, 2004 09:35 AM
civicguy1xxxxx
Jun 27, 2004 04:54 PM
