HondaCivicForum.com
-   -   white smoke (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/white-smoke-14982/)
uk civhead Jan 7, 2006 12:37 PM
white smoke
Pulled up outside my house today and I noticed quite a lot of white smoke coming from my exhaust,the engine was warmed up so it couldnt be that it was cold. I changed the oil 2000 miles ago and swopped from semi syn to fully syn castrol gtx magnatec, since then the engine has run smoother but it has used a little oil where as before it didnt use any, the mileage is bang on 80k which isnt a lot for this car, does anybody know how to cure this problem? cheers guys
drbyers Jan 7, 2006 12:52 PM
RE: white smoke
oil leak into the engine...
AgentofDarkness Jan 7, 2006 01:08 PM
RE: white smoke
Isn't white smoke burning coolant? Burning oil is bluish smoke.
drbyers Jan 7, 2006 01:13 PM
RE: white smoke
my RX-7 used to burn a LOT of white smoke. my problem was definitely oil leaking into the engine.
but still, it could be coolant.
AOL.COM Jan 7, 2006 03:49 PM
RE: white smoke
white smoke=antifreeze=blown head gasket or cracked head=[:@][:@]
mill$civic Jan 7, 2006 03:59 PM
RE: white smoke
ya when i blew my head gaskit it was the coolent getting into the engine, it was alot of white smoke
uk civhead Jan 7, 2006 04:10 PM
RE: white smoke
I dont think that the coolant has got into the engine cos theres no cross contamination, checked the oil before and it looks normal. well pi**ed me off cos i look after my civ real well so I dont understand how this has happend.
AgentofDarkness Jan 7, 2006 04:23 PM
RE: white smoke
If its a blown head gasket, there might not be any cross contamination. The coolant leaks from the water jackets into the cylinder where it is promptly burned. I don't think that the oil gets that high up into C.C. b/c it would be burned by the spark plug or the hot exhaust gases.
bshaw Jan 7, 2006 06:18 PM
RE: white smoke
ORIGINAL: uk civhead
did you check your oil dip stick then?
uk civhead Jan 8, 2006 10:54 AM
RE: white smoke
Yeah checked dipstick, oil is normal colour and near the upper marker, and coolant seems normal to.
