White smoke under the hood
Old May 9, 2011 | 05:29 PM
sammitra's Avatar
Default White smoke under the hood
Hi,
I have a 2001 Civic LX with 100,000 miles. On highway drives more than an hour sometimes white smoke starts coming from under the hood with a burning rubber smell. It happens occasionally. When the smoke is little less, I tried opening the hood and see inside. Nothing looks like burning. The lower potion under the engine is wet along the bottom iron bar. Smoke seems coming from the liquid. I don't know what is leaking. One or two drop only comes on the road after stopping.
Again the problem only happens once in a while. The car does not look overheating (the temperature gauge stands just below half way). I am haivng absolutely no idea what is going on. Checked the fluid levels for Break oil, Power steering oil. They look ok. Please help.
Thanks!!
Old May 10, 2011 | 05:21 AM
Probably a coolant leak. Check the level in the radiator (as well as the plastic tank) when the engine is cold. Radiator should be completely full to the top. Also notice what coolant smells like. Is that the same smell as the white smoke?
Old May 10, 2011 | 08:34 AM
sammitra's Avatar
thanks!! I'll check and let you know.
Old May 11, 2011 | 03:25 AM
sammitra's Avatar
Checked the coolant in the radiator today. Its filled to the top. The smell also does not match. What else it can be?
Old May 11, 2011 | 04:04 AM
norcoshore's Avatar
could be oily belt
bojadada
Mar 29, 2014 05:53 AM
slideking
Nov 20, 2010 05:10 PM
Luithicca
Mar 12, 2007 01:00 AM
mx6s girl
Mar 28, 2005 05:26 PM
niteryder
May 29, 2004 11:35 PM
