window
Old Feb 9, 2007 | 02:32 PM
BillyB98's Avatar
Default window
My drivers side front window is off the track and i cant seem to get it back on. I have the door panel all the way off and can see that it is off the front track. The back is still on fine but the front is what is limiting its movement. How can i get it back on the track? Is there anything special i need to do?
Old Feb 12, 2007 | 09:07 AM
Default RE: window
Easiest way I can think of is toremove the two bolts on the bottom of the window, holding it to the regulator. Once those are out, you will have free motion with the window. Pick it up at at angle, raising the rear of the widow first. Tuck the front of the window into the front track (front track may need adjusting, this is a good time to do so, being as the window is out) then slide the back into the back track. Push window down until it sits pretty on the bottom of the regulator. Put the bolts back in, and give it a shot!
These are the bolts I'm referring to.. There is one shown in this pic, the other is in the same position but towards the front of the car.
[IMG]local://upfiles/2331/BE64A1F622304FBE8C271A8548E18F32.jpg[/IMG]
Rattlin_Steele
Jun 6, 2011 10:45 AM
AGibney
Dec 29, 2009 05:59 PM
duffycivic
Nov 11, 2004 11:46 PM
NTX
May 4, 2004 07:12 PM
