Window Problem..
Old Sep 6, 2010 | 11:52 PM
cosmicutopia's Avatar
Default Window Problem..
I searched and couldn't find any situation as specific as mine, so I'll post here. My drivers side window (automatic) stays stuck at about halfway down. I can push down hard on the window and it won't go any farther down and when I want it up I have to grab it from both sides and lift it up and tape it so it will stay. When I attempt to roll it up, I can hear a very small noise coming from the window switch. If I grab it from both sides it is very loose and I am able to move it around.
So, is my window just off track here? Or do I need a new regulator?
Months leading up to this I had an increasingly hard time rolling it up as well.
Old Sep 7, 2010 | 09:57 AM
reznunt's Avatar
take off the door panel and check to see if it's off the track. that's what it sounds like. if it is, re-align it, tighten the bolts, and shoot a little lube on all the joints while you're in there. i did the same to my girl's ek a few years back and it's been good ever since.
Old Sep 7, 2010 | 11:09 AM
The main reason they "fall of the track" is because the regulator is worn out.
Old Sep 8, 2010 | 09:27 AM
reznunt's Avatar
and i didn't have to change the regulator.
Rattlin_Steele
Jun 6, 2011 10:45 AM
AGibney
Dec 29, 2009 05:59 PM
lilVgurl
Apr 9, 2006 06:59 PM
tmac4prez
Jul 1, 2005 02:34 PM
