wiper fluid problem?
Old Apr 20, 2010 | 07:43 PM
kfreddy's Avatar
Default wiper fluid problem?
It's a pretty lame problem, but i figured maybe someone might know an easy repair.
if any.
but, my windshield wiper fluid sprayer doesn't work..... i'm thinking it might be the switch, because i know my wipers work, cuz... they work... but when i pull back on my lever, nothing happens, i would expect the spray to not spray but the wipers to still go if it was some sort of hose problem or something, but nothing happens at all.....
any ideas?
Old Apr 20, 2010 | 09:41 PM
Maximus from the 915's Avatar
I take it you already checked the reservoir and the hose right? Once, my nozzles were broken where they connect to the hoses. If not, there's probably a small pump that may be jacked up.
Old Apr 21, 2010 | 01:56 AM
Pulling back on the lever isn't supposed to make the wipers move, it only makes the washer nozzles spray. So you're fine on that.
Do you hear the washer pump motor when you pull back on the lever?
If not, then either the motor is dead or it's not getting any power.
If you hear the pump make noise then it is working. Your nozzles are probably clogged, or even the washer fluid pump might be clogged.
At the bottom of the washer fluid tank (behind the fender liner) is the pump. Pull it out of the tank and let the fluid drain out into a bucket or something. Then clean the pump as needed.
To clean the nozzles, first remove the hoses from them on the underside of the hood. Then from the underside of the hood push on the clip prongs built into the nozzle housing. Remove the nozzles from the hood (remember which was left and which was right unless you want to have to re-aim the nozzle jets). Now take a needle and put it in the nozzle jet. Rinse the inside of the nozzle thoroughly.
The reason I had you remove the nozzle from the hood in these instructions is so that you can get all of the sediment/buildup out of the nozzle. If you just insert the needle without rinsing out the nozzle, the buildup will just work its way back into the nozzle jet over time. It would be kind of difficult to rinse out the nozzle while it is still on the hood without getting water all over the place.
Clean out the washer fluid tank so that there is no sediment/buildup in the bottom of the tank.
You should also flush out the hoses with water. To do this just leave the hoses unplugged from the nozzles, plug the pump back into the tank, and then fill up the tank with water. Point the hoses so they spray away from the car and not all over your engine bay... or point them through the engine bay so they spray on the ground underneath. Run the washer pump until you feel satisfied with the flushing. If the pump does not provide adequate pressure to clean the hoses, use a garden hose or something at the end of the hose instead of hooking it to the pump.
Alternatively, use an air compressor to blow out the lines.
Old Jul 26, 2022 | 08:09 PM
New2DIY!'s Avatar
Default I have had to buy 3 sets of sprays in the last 2 months!
Hi kfreddy! Not sure if your problem is the same as mine but I have a 2019 Civic Sport & the sprayers are garbage! They keep breaking. Even after I took it to Honda to replace they are breaking for no apparent reason! So maybe yours have broken as well and you didn’t notice. The water might be going all over you engine. Be careful because my battery got all weird and one of the relays blew and the multi fuse did as well!!
Originally Posted by kfreddy
It's a pretty lame problem, but i figured maybe someone might know an easy repair if any.
any ideas?
mnnhk5
Aug 16, 2011 03:11 AM
Finney_3
Jan 4, 2007 09:37 PM
stick only
Jan 4, 2006 09:05 PM
baboyer22
Nov 22, 2005 09:40 AM
terkel
Dec 26, 2004 07:52 PM
