Windshield Washer Problem
Old Aug 13, 2011 | 03:41 PM
mnnhk5's Avatar
Default Windshield Washer Problem
My 2008 front windshield washer no longer spray water. Please advise how to fix this problem. Thanks
Old Aug 14, 2011 | 01:22 PM
maachan513's Avatar
Make sure there is water in tank.
Have someone operate pump and listen for pump operation.
If pump is running but no spray, look for clogged nozzles or kinked tube.
If pump is not running, perform troubleshooting with wiring diagram referenced.
Old Aug 15, 2011 | 07:29 AM
techtalk's Avatar
This may seem painfully obvious but you checked the wind shield washer fluid level recently? Sometimes the solution to problems happen to be the most obvious ones. Ask me how I know..
Another possibility is that the wind shield washer motor has gone out and needs to be replaced. If this is the case, here is how you would replace said motor:
1. Remove the right inner fender.
2. Disconnect the washer motor and fluid level switch wiring harness.
3. Disconnect the washer tube.
4. Remove the mounting bolts and remove the washer reservoir (refer to 2008 Civic wind shield washer diagram)
To install:
1. Installation is the reverse order of removal.
Hope you get to the bottom of this issue!
Old Aug 16, 2011 | 03:11 AM
mnnhk5's Avatar
Thanks for the advice. Please provide instruction and picture (diagram) on how to take out the right inner fender. thanks
DarkSun
Jan 10, 2008 11:05 AM
stick only
Jan 4, 2006 09:05 PM
baboyer22
Nov 22, 2005 09:40 AM
lilleyen
Feb 27, 2005 10:48 AM
terkel
Dec 26, 2004 07:52 PM
