wiper switch/control broken physically
Old Apr 10, 2006 | 02:43 AM
jbum's Avatar
Default wiper switch/control broken physically
The wiper control (the one to the right of the steering wheel column) seems to be physically broken.
Usually, you can pull it down and it will activate the wipers until you let go of the control lever.
You can also pull it towards you to activate the washer fluid. However, it seems the recoil
action is not there. Instead, the control lever just hangs and is loose. In fact, if I leave
it hanging, it activates the wipers and they don't go off until I prop the control lever
up with something.
Has anyone had experience with this? I'm thinking about taking apart the steering column
covers and taking off the wiper switch/control to see what's wrong. Any ideas/suggestions?
Thanks,
jbum
Old Apr 10, 2006 | 04:24 PM
Stimpy's Avatar
Default RE: wiper switch/control broken physically
What year car is it?
on my 95 CX you can drop the steering column onto the seat by removing the plastic and metal panels from below the steering wheel, then removing two bolts and two nuts holding the column in place. Then you can get a good look at that control.
I think you'd have the best luck just finding out how to replace it and nabbing one from a salvage yard.
btw.. watch the airbag if you start dinking in that area
Old Apr 10, 2006 | 06:24 PM
jbum's Avatar
ORIGINAL: Stimpy
it's a '93 dx. i'll only be taking off the cover and taking off the wiper control. should i be worried about the
airbag? i won't be touching anything else.
Old Apr 10, 2006 | 06:29 PM
ef4life's Avatar
yeah especially be careful with airbags. it only takes the tiniest amount of electric current to set one off.
Old Aug 10, 2013 | 09:17 AM
prism's Avatar
I have a 95 Civic DX with a parasitic battery draw so I end up with a dead battery. I suspect the wiper control arm may be the issue. The lever won't stay firmly in the up/off position since something broke on the inside a few years ago. They go on when I drive over bumps, RR tacks, etc. How would I test for that? I've been reading up on fuses, and how to test with a multimeter. Is the arm even a viable suspect?
mudferret
15
Jan 4, 2018 08:37 AM
Mamboking25
Aug 29, 2008 07:03 AM
95ownermn
Mar 10, 2008 07:55 PM
jbum
Apr 28, 2006 07:57 AM
