wont start
Old May 20, 2010 | 10:17 AM
rapelyea's Avatar
Default wont start
I recently put a reman D15B7 in my 1995 lx it has spark and it cranks but will not start replace the coil ICM cap rotor plugs and wires. Is there anything im missing?
Old May 20, 2010 | 10:37 AM
Well is the fuel pump priming?
Old May 20, 2010 | 10:53 AM
Check ground wires on the thermostat. Check that the ECU powers up, when you turn key on but don't crank the CEL should go on for 2 seconds then back out. During that time, like Nike said, the fuel pump will prime.
Double check timing-- take upper timing belt cover off and set engine to TDC1. Then take distributor cap off and see that rotor points to #1 and other wires are in correct order (1-3-4-2 going clockwise looking at the top of the cap.) I and a couple of others here have found it possible to put the distributor on 180 degrees out of time, though others swear that it can't happen.
Old May 20, 2010 | 11:30 AM
rapelyea's Avatar
fuel pump does prime and ecu powers and all grounds are connected. double checked firing oder its right timing seems fine.
Old May 20, 2010 | 12:57 PM
Next would be to put the jumper in and see if there are any ECU codes (sensor problems) also check that the MAP and TPS are not crossed (plug with a solid white wire goes on MAP). Disconnect the return hose, click the key on to prime, to be sure that fuel is reaching (and leaving) the fuel rail. And do a compression test, maybe this "reman" engine isn't so great. If the valves are adjusted too tight there will be no compression and it will not start.
Old May 20, 2010 | 01:36 PM
Check for spark at the plugs.
Old May 20, 2010 | 02:18 PM
rapelyea's Avatar
thanks for all the help got it started and it runs great it was the firing order i mis read the book aint that a bitch
David_S
Oct 24, 2013 10:06 AM
bmelloh
May 16, 2009 08:01 PM
niteryder
Dec 29, 2004 06:47 PM
AndyI
Oct 6, 2004 09:36 AM
89 pos
Jun 25, 2004 05:35 PM
