WONT START, BET YOU CANT ANSWER
Old Nov 18, 2007 | 09:34 AM
  #21
skibum853's Avatar
Default RE: WONT START, BET YOU CANT ANSWER
i think your on the right track.
Old Nov 18, 2007 | 11:08 AM
  #22
Type RB's Avatar
I hate to ask, but did you remove ALL of the line blocks from the fuel pump, filter, lines, etc. when you installed them? Just checking - that would block your flow. Is the filter in backwards by any chance?
Try cranking it after opening the fuel tank by removing the cap. Having too much back pressure could prevent the fuel system from operating properly as well.
Simple stuff can be the most difficult to track down sometimes.
Old Nov 18, 2007 | 11:33 AM
  #23
HONDASENCE76's Avatar
Could be genius. Pulled injctor witch fires perfectly, while turning the engine (with paper towel in hole) engine started and ran but stopped because flow stoped. Every now and then flow would start again by blowing through hose.
Put 5 gallons in tank when replaced but must not be enought to create prime that is consistant. Also may have over tightened gas tank to tilt up at fuel pump side that makes it shallower than supposed to be.
Will repost later when go get gas tomorrow and loosen tank about a 1/2 to 1 inch.
PUT GUN UP
Old Nov 19, 2007 | 02:22 PM
  #24
LAST POST! RUNS! Its allways the simple stuff. Filed up and pump primed and runs. Thanks to everyone that helped me solve this delima and think through this problem.
Atleast car has all new stuff now and runs great (it better).
Sometimes you just have to take a break step back and think. THANKS AGAIN
Signed,
Still feel like a idot.
Old Nov 19, 2007 | 02:29 PM
  #25
95gsr's Avatar
lol, yeah priming wouldve helped
congrats though
colby_666
Nov 24, 2007 01:53 PM
colby_666
Nov 23, 2007 06:43 PM
WhiteRabbit1021
Jan 22, 2007 07:45 PM
POLYTHING
Jan 9, 2007 03:01 PM
Street Sniper
Jun 23, 2005 05:18 PM
