Y7 to y8
Hi about a month or two ago I swapped my y7 motor to a y8. I had a shop do the work and I'm reluctant to take my car back to them, they didn't seem to know what they were doing. But my questions are with having done the swap it seems that my car is a little slower off the line and the top speed is also slower, it's a 96 lx auto. Is it possibly that the transmission is keeping it from going faster. Some friends have said that maybe the shop didn't tune it correctly but I don't know much about swapping and doing all that stuff
Check the spark timing. That's all there is to "tune" on a stock setup. If they didn't swap the ECU and hook up the VTEC solenoid, it is going to run just like a Y7 because the VTEC will not work. Still it should not be slower.
It's not really a "swap" like using an entirely different engine series would be. Sounds like you're converting from a stock Civic DX to a stock Civic EX. |
Yea it was the lx to ex. They said they put in the ex ecu so I'll check out the timing and the solenoid thanks for the help
There is a writeup somewhere in the DIY section about setting your ignition timing. It's pretty straightforward but requires you to have a timing light. (Easy to use, rent from Autozone or something.)
Thanks for the help I'll be checking this weekend to see if it fixes my issues
