~250whp with a Z6
Old Jan 14, 2009 | 09:25 AM
Originally Posted by bcrichguitars
LSD is good to have. Maybe someone could tell you if the JDM D15B LSD Tranny would fit a USDM D16? That is the tranny I have and I've never had a problem.
yea it fits
Old Jan 15, 2009 | 02:24 PM
BLaCkSiLo's Avatar
alright, so it's not really needed then? i will probably shoot for the stock housing with an LSD... any brands? qualfie?
also what about the stock axles holding that kind of HP? i don't plan on dragging it too much so the launching aspect it alright...
so i think the tranny has a slight leak, where would that most likely be coming from? i will take a better look when i strip it down, is there some sort of a gasket/seal kit when you machine the engine? cause this thing kinda leaks from all sorts of places... ha
thanks!
Old Jan 15, 2009 | 02:36 PM
ej6buddy's Avatar
crank seal probably depending on the location of the drip.
Old Jan 18, 2009 | 11:43 AM
BLaCkSiLo's Avatar
Well yeah that's what I was thinking as well but I just replaced the front crank and timing belt about 2 months ago and the rear main was done with the clutch about 6 so any other suggestions? Seems like the tranny is leaking as well?
Any other common leak points?
Old Jan 18, 2009 | 12:02 PM
rear main seal
