boost controller Q
Old Jun 7, 2005 | 10:33 AM
riceburner700's Avatar
Default boost controller Q
I am curious if you have a d-series motor with stock internals and you put a turbo kit on it and run like 7lbs until the turbo is broken in and then you put a boost controller on it and run 10lbs will the engine be able to handle it like as a daily driver?????????[sm=happy046.gif]
Old Jun 7, 2005 | 07:45 PM
sacicons's Avatar
Default RE: boost controller Q
doubtful. MAYBE on 93 octane, but youd be pushing your luck. and only if it was tuned on a dyno would it last very long, even on race gas.
Old Jun 7, 2005 | 09:19 PM
i only run 92 octane but i dont want to take any changes so i think i will just stick with the 7lbs and keep it at that.....i am also gonna upgrade to an....
aftermarket fuel rail
aem fuel regulator
and maybe a new fuel pump depending on how hard it is to get to.....
o yeah and maybe some really small performance injectors but not for a while should this give me a pretty decent boost in power without any chances.....
Old Jun 8, 2005 | 01:00 AM
redcivic99's Avatar
i have t3/t4 to4e and was runiing 10psi, it ran really well for about 1 month and now it sits with two cracked pistons, so yea i would stick with the 7 psi
Old Jun 8, 2005 | 05:20 AM
99civic_boosted's Avatar
Greddy turbo at 10psi cracked three of my pistons, replaced them with 4 others I had. Less them a month later cracked another.
ARP's is the fix for that.
lilpooh21186
May 31, 2006 01:09 PM
allstock
Mar 25, 2006 04:25 PM
nemesis08
Nov 13, 2005 05:25 AM
dbaseballn
Aug 30, 2005 10:09 AM
silvic00
Jan 27, 2005 01:14 AM
