boost my stock d15?
Old Oct 10, 2005 | 09:15 AM
gili_91hatch's Avatar
Default boost my stock d15?
should i boost my stock d15 on my 91 civic? i want turbo, but how do i do this and what do i need, i am still new to the racing world[&:]
Old Oct 10, 2005 | 09:26 AM
Nail I3unny's Avatar
Default RE: boost my stock d15?
blah. dont boost a D15. its a waste of time and money. swap in a ZC and boost that.
Old Oct 10, 2005 | 10:11 AM
well i already have a b16 sir in mind right now, but can that be boosted also and how much hp will it add? since the b is pushing out 170 n/a?
Old Oct 10, 2005 | 11:37 AM
Kappa22's Avatar
Sure, the B16 can be boosted, but it's high CR and low displacement mean you can't run more than about 6 psi. You can run more than that on a stock 4G D15 (not that it's important), so it's really up to you. If you really want to go boost for not too much overhead, I'd say go with an LS motor (which will only cost you 1/2 to 2/3 as much as a B16) and boost that.
Old Oct 10, 2005 | 01:37 PM
Street Sniper's Avatar
I'll buy your d15 when you swap it.
Old Oct 10, 2005 | 08:00 PM
riceburner700's Avatar
read the sticky not at the top of this section about DIY turbo's really good info, and i think boosted d's are pretty dope but that is just me.
Old Oct 19, 2005 | 12:41 PM
PicknFLick's Avatar
What all does that do your gas mileage?
Ive got a '93 Lx with a d15 and was thinking about turbo, but i havent decided. How much will it lower the mpg?
Old Oct 21, 2005 | 09:15 PM
JMaC's Avatar
so how much time/money is being wasted, how much hp i atainable
Old Oct 23, 2005 | 05:16 PM
it all depends on the money and time you put into it. if you boost the D15 you'll be looking at maybe 160hp...depending on the tuning and the turbine. if you swap for a B16 or B18 you'll be looking at maybe 230-260ish boosted...again depending on the tuning and turbine. as for MPG..if its not done right it will kill it....but after you get a good, professional tune it can actually increce your gas milage.
Old Oct 23, 2005 | 07:52 PM
Kappa22's Avatar
The reason D's are less than ideal for boosting compared to B's is their short conrods. When the extra force of FI is acting on the crank and rods, they are exerting much more lateral pressure on the cylinder walls than longer B-rods. When too much boost is applied, it causes dangerous amounts of cylinder wear and often leads to nice big holes. Therefore, significantly more internal work is required on a boosted D to get it to the same power levels as a boosted B (when you're running about 10+ psi) and run reliably for a long time. That's not to say you can't run 6-7 psi all day, all year on a D though. Just don't try and run it like a 4G63...
